Scripting Designmodeler - create skin out of line bodies - named selection |
#1 | ||
Max
Rep Power: 11 ![]() |
I'm writing a Script (with MATLAB) for Ansys Designmodeler to get a volume of a complex tooth geometry. I've imported a cloud of Points and created Line Bodies from this Points. The Points define two tooth flanks. Every flank has the same number of Points and is mirrored. Now I want to use the Skin/Loft to get a Volume. In the Ansys Help I could find the Scripting for Skin/Loft: Quote:
Now my question: Can somebody help me and give me a hint how to write script for named selection of line bodies. It would be usefull not to just give me the code - please explain to me what to do - i want to understand what I'm doing! I want to skin each "mirrored" Line Body ... Best regards Max Last edited by USER1234; May 20, 2015 at 03:52. |
line bodies, named selection, script, skin |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
[ANSYS Meshing] Multiple line select for named selection | Tanjina | ANSYS Meshing & Geometry | 8 | October 17, 2013 14:16 |
Creating named selection for a line sketch | amir00251 | ANSYS | 6 | July 31, 2012 08:02 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
