How to adjust colormap
Old   April 26, 2015, 23:43
Exclamation How to adjust colormap
yas6ser is on a distinguished road
Hi everyone,
I'm doing ansys fluent on ansys 15.
my project is to make 3 different velocity in a pipeline. for all these 3 I'm having 3 different color-map, it's difficult to compare between them.
how can i make 1 color-map to shows the different between them and to make it easy to compare? to be looks nice in my report.
pic are attached
thanx in advance,
yasser
yas6ser is offline   Reply With Quote
Old   April 29, 2015, 14:11
fresty is on a distinguished road
It's pretty convenient i believe, just explore the max & min values and other scale properties, i am sure you will get your answers there. Go to the respective CFD-post modules, then the properties of your default colormap/ legend and look around for the max magnitude/ value for each and set it to the highest (or slightly >highest) magnitude of velocity achieved from the above 3 cases.
fresty is offline   Reply With Quote
Old   May 4, 2015, 21:58
Thank you for your answer
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 10:45
[ICEM] Adjust mesh thickness in ICEM 11.0 vmlxb6 ANSYS Meshing & Geometry 0 August 14, 2012 15:27
How to adjust wall temperature nutow FLUENT 0 September 4, 2011 06:37
ADJUST udf Jubs FLUENT 3 February 12, 2007 07:00
fluent v5.3 colormap Kai Kang FLUENT 0 January 31, 2000 18:20
