Unexpected error while using ansys
Old   April 11, 2015, 02:10
Default Unexpected error while using ansys
fluentspace is on a distinguished road
I have recently installed ansys, but it is showing some unexpected , as i use it it is not allowing work flow from one cell to another, first i tried to design a model in the design modler then as i tried to import it to meshing it is showing plugin error and failed to attach geometry , i have enclosed an image of the error message it is showing. Kindly offer any solutions if known.I have uploaded an image of the error. It says some thing about system access violation
As far as the research i had done most of it says that i have installed ansys without administrator privileges so it cannot access the files properly.Is this the actual reason ? as far as i can remember i have installed with Run as administrator
fluentspace is offline   Reply With Quote
ansys 13, instalation.
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
FLUENT installation on UBUNTU 12.04 (LTS) teymourj FLUENT 2 March 1, 2017 23:24
Unexpected error by starting Ansys Workbench alexmeier ANSYS 14 April 7, 2016 06:53
unexpected error launching Ansys Workbench caprox ANSYS 1 October 29, 2014 21:44
error 262144 and unexpected disconnect when run on 2 nodes Emily1412 SU2 Installation 1 April 10, 2014 18:08
