March 20, 2015, 10:41 |
icepak workbench geometry import
zduno
Rep Power: 13 |
Hello good people,
Here is my problem: I've got cad geometry which I uploaded to DM in ansys 14.0 and I would like to put it to icepak but it just doesn't work. I've got geometry component in workbench, I drag and drop icepak component on top of it and this connection is created, I open (double click or right click and edit) icepak component, icepak opens and there is nothing in there. Kind regards, Pawel |
March 30, 2015, 07:58 |
anbu
Rep Power: 12 |
hi,
Before connecting design modeler to icepak, in design modeler under tools menu, you can find electronics in that you can select simplify and specify level to three and select the component and give generate, icepak object type will be generated. then you can connect to icepak. thanks |
[Workbench] Which input file format can be used to import geometry | Irondome | ANSYS Meshing & Geometry | 1 | January 17, 2018 22:12 |
[DesignModeler] How can i get log file of geometry from ansys workbench? | eagle16 | ANSYS Meshing & Geometry | 3 | September 11, 2016 21:22 |
[DesignModeler] Unable to Import Geometry | Alan212 | ANSYS Meshing & Geometry | 3 | March 17, 2015 12:26 |
[ICEM] Import geometry from solidworks | holyo | ANSYS Meshing & Geometry | 11 | April 16, 2014 12:47 |
Geometry Import from ProE produces improper geometry | mtatro | Structural Mechanics | 2 | July 29, 2013 09:16 |
