postprocessing forces in dpm FLUENT
Old   March 14, 2015, 07:44
Default postprocessing forces in dpm FLUENT
khar nab
kharnabnew is on a distinguished road
Hi all,
I could not find any way to obtain the individual forces acting on particles directly from the results available in FLUENT. Thus, I tried to calculate them according to the formula used by fluent to account for different forces in the force balance equation. In my problem all the additional forces are neglected and only drag and gravity are there. My focus is on the drag force. The parameters I should use are confusing.
Drag force=FD*(uf-up)
FD=18*mu*CD*REp/(rhop*dp*dp*24)
CD=a1+(a2/Rep)+(a3/Rep^2)
Rep=rhof*dp*|up-uf|/mu
My problem consists in a gas-solid flow in a junction. the gas flow splits in the junction and some particles go into the branch of the junction. When the branch is upwardly directed I can see that no particles follow the gas flow which means that in the vertical direction drag is lower than the gravitational effect. I could not obtain this when I tried to plot individual forces to check which one is dominant.
Is it possible to get these forces directly from fluent? if not how to make sure which variables are used by the code? I am using FLUENT15. The particle velocity componenets are available. My flow is turbulent, so I guess FLUENT includes the fluctuating velocities in the force balance.
Thank you in advance
kharnabnew is offline   Reply With Quote
Old   October 3, 2024, 13:13
Nabil
Md Nabil is on a distinguished road
Did you get any solution to your problem? I am also trying to obtain the force on the particles that are flowing through a channel. Did you write any UDF for this?
Md Nabil is offline   Reply With Quote
Fluent DPM - incomplete particles richard ben FLUENT 4 September 26, 2014 12:37
Reading a file from 32-bit Fluent 15.0 through a UDF for DPM in parallel anthony05 Fluent UDF and Scheme Programming 0 July 11, 2014 02:52
drag and lift forces in UDF fluent Isitv2A FLUENT 0 June 27, 2014 12:36
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
Additional forces for DPM akr FLUENT 1 July 9, 2007 03:15
