March 8, 2015, 00:56 |
Solution not accurate, can't figure it out
Peter
I am a student learning to use Ansys and cannot explain my lack of accuracy.
I have modeled a NACA 0012 airfoil. Lots of published data on this so I can compare. I am getting Cl of 0.72 when I should get Cl of ~0.45 My mesh orthogonally quality is about 0.44. I am running inviscid, with energy equation on. fluid is air and is ideal-gas-law for what I assume is 'compressible' because I'm running at a mach 0.4 at 4 deg AoA. Is my problem in mesh or in my solution set up? Thank you for your help! Peter |
April 29, 2015, 12:42 |
Rep Power: 13 |
If you're still stuck with this, please, post some images of the mesh and model for better understanding.
Mesh size for DNS and LES | Glenn Horrocks | Main CFD Forum | 45 | May 25, 2020 15:43 |
Does FOAM converge to exact solution in Laplace equation? | santiagomarquezd | OpenFOAM Running, Solving & CFD | 0 | March 26, 2010 07:52 |
Abt: Schlieren figure in Tecplot using data | jinwon park | Tecplot | 2 | December 27, 2007 06:48 |
How accurate are non-convergent results? | Chris | FLUENT | 12 | April 21, 2005 03:56 |
time accurate solution | student | Main CFD Forum | 2 | December 20, 2004 15:34 |
