Solver Error during Structural Analysis
Old   February 25, 2015, 09:50
Question Solver Error during Structural Analysis
Prateek G.
prateekg92 is on a distinguished road
I have modelled a hollow beam of shell thickness of all sides equal to 2mm,by using Extrude and Shell command in PTC Creo, and then imported its .igs file to Ansys 13.0 Workbench for structural analysis. (the image is attached for getting an idea of its shape). I have applied material properties, given fixed supports an its two ends (a simply supported beam), did meshing by using Automatic method, and applied a pressure over its its entire frontal surface. I inserted Total Deformation and Equivalent Von Mises Stress in the Solution.
Now when I solve it, it gives following error and warning:
1) Error: "an unknown error occurred during solution. Check solver output on the solution info. object for possible causes"
2) Warning: "solver pivot warning have been encountered during solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model or contact related issues. Check results carefully."
I found that in the project tree that under "geometry", the part was imported as a part 1 and part 2, and not as one part.
Also, I did not provide any type of connection under the "connections".
I don't know what might be the cause of this solver error. Please help.
Thanks in advance.
prateekg92 is offline   Reply With Quote
Old   March 10, 2017, 11:17
Onur Özcan
oozcan is on a distinguished road
I have run acrossed same one.
oozcan is offline   Reply With Quote
Old   March 17, 2017, 05:08
Mehak
Mehakkar is on a distinguished road
Try to unite those parts in a Boolean operation in ansys
Sent from my ASUS_Z00LD using CFD Online Forum mobile app
Mehakkar is offline   Reply With Quote
Old   March 17, 2017, 05:57
Onur Özcan
I have only one body in model
Old   March 17, 2017, 08:13
Mehak
Can you mail me that body
solver error, strucutural analysis
FSI: fluid - structural analysis, help plz emreg ANSYS 0 December 19, 2011 13:41
CFD import into structural analysis? emreg ANSYS 3 December 18, 2011 11:47
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
2D incompressible Navier-Stokes solver for diffuser analysis of centrifugal pump WANTED !!! LI, J Main CFD Forum 1 November 20, 2003 00:49
