convergent-divergent nozzle in fluent
Old   February 3, 2015, 20:13
Default convergent-divergent nozzle in fluent
FC
frafole is on a distinguished road
I'm simulating a convegent divergent nozzle in fluent with air. I've noticed that the AreaAvarage pressure in inlet changes when I change the dimensions of the nozzle, even if I set as BC ambient pressure inlet; why does that happen? Otherwise I'm searching for the minor pressure drops from inlet to outlet, and I don't undestand why pressure drops seems that have more than one minimum value if I modify the length of the nozzle without changing the angles, but in theory pressure drops should be linear. Does anyone know what I'm probably missing?
thank you very much.
frafole is offline   Reply With Quote
Convergent Divergent Nozzle Hrishikesh Main CFD Forum 12 June 25, 2016 03:06
Solid Rocket Nozzle - Fluent 5 Tutorial Guide Ijaz FLUENT 4 April 2, 2015 21:46
How to calculate particle size at outlet of a 3D nozzle model in fluent? nishu3210 Main CFD Forum 0 January 21, 2015 14:54
Convergent divergent nozzle csmistry CFX 6 September 16, 2009 02:40
Pressdrop across in nozzle: Fluent Paul Main CFD Forum 8 January 15, 2006 03:24
