Eroded volume in explicit dynamic model?
Old   December 21, 2014, 13:29
Question Eroded volume in explicit dynamic model?
Kisorthman Vimalakanthan
k.vimalakanthan is on a distinguished road
I very new to explicit dynamic modelling in ansys so this may be a silly question.
Has anyone managed to extract the final volume of a body at the end of a simulation?
I'm interested in knowing how much of the initial volume of a body reaches the failure criteria and eroded off, basically quantify the material removed (red dots) during or at the end of the explicit dynamic simulation.
Any help is greatly appreciated,
Thanks in advance,
Kind regards,
Kishore
k.vimalakanthan is offline   Reply With Quote
Old   December 30, 2014, 22:48
Qi
qjet is on a distinguished road
You need to know the volume of the elements, and which elements eroded.
To extract the volume of the elements. Scope a user defined result to the body of interest. For the expression, use "massall/density" (Without the parentheses). The display time should be set to a time before deformation begins. Set the integration point results to elemental mean. This will display a plot of the starting element volumes. Evaluate it and export the results by right clicking on the result listed under the outline.
To get the eroded elements. Scope another user defined result to the same body. The expression is now "erosion". You can leave display time to last or change it as you see fit to study erosion evolution. Evaluate the result and export those results too.
The exported results are columns with element #, element volume and element erosion (1 or 0). You can simply multiply the element volume by the element erosion and sum up the results, which gives the eroded volume.
You can display and export other user defined results such as "status" to see other types of damage. Just make sure to use the elemental mean.
qjet is offline   Reply With Quote
Old   January 1, 2015, 09:30
Thank you very much you've solved my problem with such ease.
Happy new year
Dept. of Power and Propulsion
Cranfield University
Email: k.vimalakanthan@gmail.com
ansys, erosion rate, explicit dynamics
Volume fraction of dispersed phase to determine DPM, VOF, Mixture model Mohsin FLUENT 5 March 5, 2018 08:47
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
