December 20, 2014, 12:16 |
Problem in generating mesh file for fluent
Rep Power: 12 |
I have generated multi-block mesh in ICEM CFD.But when i generate mesh file for fluent, errors occurs as shown in the fig. Please help me.Thanks
January 5, 2015, 15:08 |
Quentin Lux
Rep Power: 14 |
Once converted in unstructured mesh, use the check Mesh utility under the Mesh tab, it will show you the uncovered faces. But usually it means that in your blocking you have faces of a block that are not linked to a surface of the geometry.
what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 20:43 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
