Hi all, I want to know the way of approach for one simple problem. Details are following. I have a copper Block, above the copper block i have heat source (ic) which is generating 70 degree Celsius heat in steady state condition. I want to know? If the (ic) is placed at middle of the copper heat sink means what will be the temperature at all edges of the copper heat sink, and where would be the intermediate temperature between ic temperature and edge temperature of the copper block ? ![]() ![]() http://public.justcloud.com/dxq838bog5.78819647 |
ansys 13 work bench, steady state thermal |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 09:23 |
FLUENT installation on UBUNTU 12.04 (LTS) | teymourj | FLUENT | 2 | March 1, 2017 22:24 |
[snappyHexMesh] .STL: non-closed manifold surface | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 32 | November 25, 2016 03:15 |
[ANSYS Meshing] Workbench 13: Structured Hexa Meshes | rooftop | ANSYS Meshing & Geometry | 19 | March 31, 2016 02:33 |
Question on running CFX simulations in workbench parameter set table | Anna Tian | CFX | 0 | September 20, 2014 01:51 |
