Error in FSI simulation
Old   October 27, 2014, 03:29
Question Error in FSI simulation
Siamak
siamak1438 is on a distinguished road
Hi Everyone,
I am simulating simple 3D heart Valve by using fluent FSI version 15. As you know, the young modulus and the Poisson ratio of the artery are very high and low, respectively. When I run the simulation, most of the time in the first iteration gives me an error due to highly distortion of the mesh. I am changing time step and stabilize factor (increase the stabilize factor in the volume method). Anyway after a couple of solution again the solution diverges (I am checking the force in the deforming wall) and it crashes. Does anyone know how can I fix the instability of the problem? Is there any tutorial to show how can I deal with low-young-modulus materials?
Also, the boundary conditions are the velocity inlet (a profile is defined by UDF) and the pressure at the end is the pressure outlet with zero relative gauge pressure.
Thank you
Siamak
siamak1438 is offline   Reply With Quote
Old   December 2, 2014, 17:39
anbu
anbu2cfd is on a distinguished road
Make fine mesh
anbu2cfd is offline   Reply With Quote
Old   December 2, 2014, 17:42
anbu
Reduce ur time size , to get a solution initially run the simulation fr a higher modulus then yours
My FSI simulation (pipe-flow) vitorspadeto OpenFOAM Programming & Development 1 September 24, 2014 18:27
Problem FSI simulation Workbench Huski CFX 0 November 12, 2012 15:14
Ansys FSI and CFX (valve simulation) farianka ANSYS 0 April 17, 2011 17:20
parallel run for fsi simulation??? smn CFX 2 July 19, 2009 05:04
problem in solving fsi simulation siavash CFX 5 July 10, 2009 12:59
