Prism problem in ICEM CFD at inlet and outlet |
October 24, 2014, 18:23 |
Benjamin Hogan
Rep Power: 12 |
Relatively new user looking at meshing a case for exterior aerodynamics of streamlined vehicles, in particular a wind tunnel validation study. My problem is prism generation on the floor boundary not running to the inlet and outlets correctly. This causes the prisms to decrease to a small point which ultimately leads to terrible quality cells. Please see the attached picture that I hope explains my issue. I am aware that the mesh appears quite coarse - I am just trying to eliminate the prism problem. Any help or advice welcome. Cheers! Ben |
November 11, 2014, 06:55 |
mohammad
Rep Power: 16 |
If your geometry is not very complex, try using blocking...then you will have easy time with the prism layer
November 15, 2014, 12:17 |
davide basso
Rep Power: 14 |
check the value of Max Prism Angle parameter under Global Prism Mesh Parameters. If you have 90 or less that may cause the error |
cfd, icem, inlet, outlet, prisms |
[ICEM] ICEM CFD Problem with the boundary conditions while importing the mesh to fluent | sonic109 | ANSYS Meshing & Geometry | 2 | September 3, 2014 01:56 |
1 Inlet 2 Outlet BC setup problem | vbchris | OpenFOAM | 1 | March 8, 2013 02:38 |
total pressure boundary problem ==> flow from outlet to inlet!! | mrshb4 | OpenFOAM | 0 | November 20, 2010 13:41 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 16:45 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 09:07 |
