steve
Rep Power: 11 ![]() |
Hi
I'm new to Ansys 15 design modeler. I've done what I am trying to do before using gambit/fluent and for some reason I can't seem to replicate the same workflow with design modeler. I've tried several different ways but so far no luck. Here's what I am trying to do. I have a solid part made with solidworks - actual solid that is hosting a fluid (liquid water). This solid is complex but overall it is simple volume with an inner cavity that opens up to the outside with 2 holes, on is the inlet and the other is the outlet. When I import this file in Design Modeler, my goal is to end up with 2 bodies - one solid and one fluid. Where the surface common to both bodies is a named selection called interface. So I've tried importing: - a solid and the matching fluid bodies - solid and 2 caps (other bodies which I then removed after using the fill function) - a solid and the fluid bodies and 2 caps... - I've tried combinations of importing as an assembly and as a part. I think the solution is to import as a part but I get weird import problems where the 2 bodies would be merged and only 1 body and 2 surfaces would be imported. Is there a way to do this with the boolean function? I mean, I can subtract the solid and get the fluid but I need both the fluid and the solid in order for this to work. In case you are wondering, the error/problem, is that once in fluent when applying all BC I am missing the WALL interface name selection (and its shadow) where I can actually set it to thermal/coupled. All I have is the interface with no ways of editing it into to a wall to set it to "coupled" thermally. I haven't ran the simulation because I've been there before and I am sure I need this as a coupled wall. If I do run it, there will be no heat transfer between my fluid and solid. Any idea?workaround? Thanks Steve |
steve
I found a work around. I imported everything as STEP - ignored the name selection for the interface all together (the surface is way too complex anyway) and when in fluent I deleted the interface that fluent (or mesher not sure) created because it doesn't have the coupled option selected. I recreated it with coupled selected. and everything worked fine.
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
