Dynamic mesh / parallel processing.
Old   October 13, 2014, 10:30
Default Dynamic mesh / parallel processing.
Giulio.Biscarini is on a distinguished road
Dear all,
I'm modeling a flow over an oscillating cylinder.
Initially i run the serial solver of ansys and everything went good, but when i run the prallel solver fluent gives me differents types of error like:
Detected negative volume.
AMG solver prerssure or x-momentum ...
Further more i realized that the parallel solver modifies the rigid body motion. In fact as you can see in the figure the cylinder is deformed while it should have been moved like a rigid body.
How can i fix this problem??
Thank you!!!
(I apologize for my bad english ... )
Giulio.Biscarini is offline   Reply With Quote
Old   January 4, 2015, 12:35
Catthan is on a distinguished road
Hi, have you had any luck with this?
I'm doing dyna mesh runs but always avoided parallel solver 'cause of errors like yours.
Please post back or even PM me if you have found anything that solved your problems.
Catthan is offline   Reply With Quote
Reconstruction of the parallel case with dynamic mesh makaveli_lcf OpenFOAM Post-Processing 8 December 3, 2024 12:16
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling spaceprop FLUENT 5 September 2, 2014 10:43
potentialFreeSurfaceFoam with Dynamic Mesh GuilhermeMP OpenFOAM Programming & Development 1 October 6, 2013 04:05
[blockMesh] is parallel processing available for mesh generation? sachinlb OpenFOAM Meshing & Mesh Conversion 4 August 18, 2012 05:11
