CFD Post - How to check for case in an expression
Old   September 26, 2014, 05:44
Default CFD Post - How to check for case in an expression
pilakin is on a distinguished road
I've loaded two cases into cfd post and defined expressions. I need to check the case in one expression to set an appropriate value for each case. e.g. I've got the expression "T 10" for a temperature. If it's case 1 it's supposed to be 10K and if it's case 2 20K.
I've tried
if(CASE == solution2 1 0, 10 [K], 20[K])
(solution2 1 0 being the name of the first case) but it doesn't work like this. so how do I check for the case in an if conditon?
edit: I worked around it by checking for another constant expression I know the value of for each case. still I'd like to be able to check for the acutal case name though.
pilakin is offline   Reply With Quote
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. hda ANSYS Meshing & Geometry 5 October 24, 2016 10:26
calculating output parameter in cfd post markus67 CFX 3 August 26, 2015 10:28
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 03:49
static enthalpy calculation in CFD Post newbie384 CFX 2 March 22, 2014 08:28
User CEL Function and CFD Post chastain CFX 4 September 24, 2013 14:58
