Gas/liquid volume fraction function of pressure |
Morten Bøgild
Rep Power: 0 ![]() |
Hi there,
My simulation case is a porous core containing a liquid. The outer pressure is slowly decreased and I want to study the gradient of the pressure in the core. This works fine. Now to spice thing up: The liquid contains gas, which at a lower pressure will start to dissolve - just like CO2 in Coca Cola. The volume fraction of gas will increase when further decreasing the pressure. The volume fraction of gas follows a given function, and thus the volume fration of the liquid is also known. However, I do not have an inlet to specify the volume fraction as a function of pressure, so I need to specify the volume fraction in the whole core as a function of pressure. I can only specify volume fractions as initial conditions in a domain, regardless of CFX or Fluent. Ideas or comments anyone? Thanks, Morten |
cfx, fluent, multiphase, volume fraction |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 02:39 |
