Vertical axis water turbine simulation
Old   September 16, 2014, 02:06
Default Vertical axis water turbine simulation
shikha
SHIKHA BHUYAN is on a distinguished road
Goodevening friends,
I am working on water turbine simulation and have to use ansys workbench for the same. I have to create a rectangular domain for the water flow over the turbine which will make the turbine rotation (water flow will drive the turbine)
I am new to this field. So, can anyone suggest me any tutorials for this meshing and simulation. Any help will be highly appreciated. Thank you in advance.
Regards
Shikha Bhuyan
SHIKHA BHUYAN is offline   Reply With Quote
Problem with torque output from a turbine simulation. pa-dundas FLUENT 5 July 17, 2022 06:27
[ICEM] Boundary conditions in copy-rotate 3-bladed vertical axis wind turbine pollenhavy ANSYS Meshing & Geometry 2 February 17, 2017 18:01
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
Vertical axis wind turbine simulation vincentwks ANSYS 0 April 10, 2012 05:27
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 08:10
