Meshing of 2D centrifugal fan
Old   September 5, 2014, 10:14
Default Meshing of 2D centrifugal fan
Parvesh
The_Dude is on a distinguished road
Hi guys. Can anybody give me some tutorial on how to mesh the 2D centrifugal fan in ansys workbench. Here we are dealing with rotating frame so i am not sure how do define solid fluid interface. I have made a sketch in ProE, whats the best way to import that to workbench? also can i import the sketch directly to ICEM and mesh there?
The_Dude is offline   Reply With Quote
Old   September 10, 2014, 20:13
Adriana
adruma is on a distinguished road
Did you try MRF? (it stands for moving reference frame). I know this is used a lot in Icepak, but I have not used it in Workbench. I import lots of files from CAD to Workbench, but they are Solidworks files, so typically I import STEP file.
Adriana Druma
Aavid Thermalloy
Design engineer
adruma is offline   Reply With Quote
Old   September 11, 2014, 05:53
Parvesh
Adriana Druma
Aavid Thermalloy
Design engineer
Hi Adriana! Yeah i have imported step/iges files to workbench using proE. But here we have a 2D fan, so do i need to generate a surface from the sketch before meshing in workbench or i can directly mesh a sketch? I am kinda new to ansys so i am not sure how to go about it. I dont even know if i can import a sketch in workbench. I have replicated the moving frame tutorial in the Ansys tutorial guide but there mesh was already available for the blower. I want to create my own geometry and mesh and i am confused whats the best way to do it.
Old   September 24, 2014, 02:26
rahul kumar
R4RAHUL is on a distinguished road
you have to create a surfaces from your sketch then you will be able to mesh it. when you draw your sketch then it will show you 0 parts 0 bodies but when you make surface it will show you 1 part 1body
R4RAHUL is offline   Reply With Quote
Radial velocity and tangential velocity on centrifugal fan, johnnyp FLUENT 2 May 24, 2013 08:10
Modeling of centrifugal fan in CFD Simon Williams Main CFD Forum 3 February 20, 2009 16:00
How to model flow of centrifugal fan? Peter Main CFD Forum 0 April 2, 2008 07:07
meshing fan blade in tunnel... fadly CFX 4 August 10, 2007 17:52
centrifugal pump and centrifugal fan Mangesh Main CFD Forum 3 January 3, 2006 12:21
