ERROR #002100012 has occurred in subroutine Out_NegVol.| negative ELEMENT volume
Old   September 3, 2014, 06:19
Default ERROR #002100012 has occurred in subroutine Out_NegVol.| negative ELEMENT volume
kg1913 is on a distinguished road
My first model is running without problems. But after I change the geometry slightly of that model and re-associate everything. It will give me this error below.
This happened also to another different model after changing the geometry slightly. Could someone give me a hint please what I am doing wrong?
[the associations are correct and I have done the mesh check too]
Thanks
| ERROR #002100012 has occurred in subroutine Out_NegVol. |
| Message: |
| A negative ELEMENT volume has been detected. This is a fatal |
| error and execution will be terminated. The location of the first |
| negative volume is reported below. |
| Volume : -0.1217E-12 |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver could not be started, or exited with return |
| code 255. No results file has been created. |
End of solution stage.
This run of the ANSYS CFX Solver has finished.
kg1913 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Courant number blowing up, non-orthogonal mesh? odellar OpenFOAM Running, Solving & CFD 5 October 22, 2013 20:50
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
negative volume encountered Maga CFX 2 October 7, 2009 18:31
