Exporting Velocity Vectors
Old   August 27, 2014, 05:11
Default Exporting Velocity Vectors
Lauren Dransfield
ld1305 is on a distinguished road
I can't find anything when I've looked myself, so figured I'd try here: Is there a way of exporting the velocity vectors (and positions of each) from Fluent or CFD-Post at each node? I'd prefer them to be a text file, or CSV (something that's essentially just values)
I'd specify 2D or3D but to be honest both/either would be great. I currently have .cas, .dat and .cdat files saved, and don't mind writing journals etc to get what I need, I'm just not sure where to start.
ld1305 is offline   Reply With Quote
Old   October 21, 2014, 11:18
pilakin is on a distinguished road
I don't know a method directly in fluent or cfd-post.
you can loop over all nodes and write a file with an UDF though. so if you have some experience with UDFs ...
pilakin is offline   Reply With Quote
Old   October 23, 2014, 04:49
Lauren Dransfield
I actually found a solution that worked for me shortly after posting this:
Seems pretty obvious to be honest, but it produces what I need, just had to use MATLAB to get it into a more useable format
Old   October 23, 2014, 04:50
Lauren Dransfield
I know the above shows static pressure, but you get the idea
cfd-post, fluent
Errant Velocity Vectors in Rotating Reference Frame Prop Sim Muzz STAR-CCM+ 1 August 21, 2014 11:22
problem with velocity magnitude and vectors Hayder Mohammed FLUENT 0 August 7, 2013 04:08
I need help about velocity vectors direction in cylinder modeling!!! aminepoxnet FLUENT 0 March 17, 2013 18:41
Inaccurate velocity vectors Arun Prasad FLUENT 4 August 2, 2012 01:43
how to display a clear vectors of velocity clauss FLUENT 1 October 24, 2006 08:30
