Natural Frequency Values from Analytical and Numerical Solution are different
Old   July 16, 2014, 21:23
Default Natural Frequency Values from Analytical and Numerical Solution are different
ppy1111 is on a distinguished road
I ran a 3d modal analysis, modelling it as a 3d solid using hexahedral mesh, in Ansys to obtain natural frequency of a pipe, and compare the values from my analytical solution.
When I compared it to my analytical solution my I have .5% error on 1st mode, 3.4%, 7.8%, 13.7% and 20% on mode 2, 3, 4 and 5 repectively. in this case the L/D ratio of the pipe is 18
So I decided to increase the L/D ratio of the pipe to see if natural frequency values would match at higher L/D ratio. So I increase to 50. My results show that in this case my percent errors are 2%, 3%, 3.6%, 4.3% and 5.3% on modes 1,2,3,4 and 5 which are much lower than my first case.
Does anyone know why at higher L/D ratios the percent error between analytical and numerical values are decreasing? Do you guys know any literature related to this?
ppy1111 is offline   Reply With Quote
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Analytical Solution of 2d acoustic pulse propagation JS-UDE Main CFD Forum 0 April 29, 2014 06:50
Oscillating Cylinder in Parallel Flow: Analytical Solution startingcfd Main CFD Forum 7 March 23, 2012 06:49
Analytical solution to the quarter five problem Sadek Main CFD Forum 1 March 15, 2006 10:04
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
