Problem in CFD -post
Old   July 15, 2014, 11:14
Default Problem in CFD -post
Pratik
pratikvn is on a distinguished road
I am having a problem in opening the results tab in workbench--> Fluid Flow - Fluent ( CFD post ) whenever i try to open the results, it says
ERROR
File 'Directory\dp0\FFF\Fluent\FFF.2-5-02000.dat.gz' does not exist or is not readable.
I am not able to open CFD post at all.
Can you please tell why this is happening ? And what I should do to rectify it .
Thank You
pratikvn is offline   Reply With Quote
Old   October 22, 2017, 04:51
Default Check directory
Kevin
Guera is on a distinguished road
Me too having the same problem, one possible reason is moving Ansys files to a different location, seems like the initial location is remembered by fluent gunzip files.
If anyone found a way around this problem, please help!!!
Guera is offline   Reply With Quote
Old   December 18, 2017, 06:47
Hells Blade
hellsblade.91 is on a distinguished road
Hi guera did you finally find a solution to this problem i am also having the same issue
hellsblade.91 is offline   Reply With Quote
Old   March 21, 2018, 01:31
東京都
Joni Jono is on a distinguished road
I also have same problems, and my solution was changed in to new workbench, because old result from the calculation also has impact on this calculation.
1. Just copy the geometry and mesh only in to new workbench.
2. Make a new setup
Joni Jono is offline   Reply With Quote
Old   March 21, 2018, 03:56
Gert-Jan
Gert-Jan will become famous soon enough
Alternatively run fluent as stand alone package outside Workbench.
Then you have full control of the files, meaning that Workbench can't delete files that you want to keep.
Gert-Jan is offline   Reply With Quote
Plotting the Viscosity Contour in CFD Post ashtonJ FLUENT 3 June 2, 2015 13:06
Collect transient results CFD POST mortain CFX 15 April 17, 2015 09:29
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 13:26
CEL mathematical functions in CFD Post Jonathan CFX 9 November 5, 2012 09:37
flap meshed with shell > surrounding CFD Mesh has weird look in CFD Post MainzerKaiser CFX 1 April 26, 2012 14:18
