July 10, 2014, 04:09 |
Problem with usnstruct mesh Icem Tribometer
Hello everyone ,
I am new to the forum ; I am working on my thesis for mechanical engineering ( first level degree ) . I have a problem with the generation of the grid to ICEM ; it must be an unstructured mesh 3D . The problem is that there are lots of holes between two surfaces , the most important : they are a cylinder that is drilled to the base by two conical . It is difficult to explain both the geometry and the grid . I usually generate the mesh with method robust ( octree ) , and I havo to use smooth advancing front after that . My experience is limited, so I hope that someone will give me some advice . Thank you ! P.s. : is it possible to upload my icem file ? |
[ICEM] ICEM Structured Mesh Problem | OMJT | ANSYS Meshing & Geometry | 3 | March 22, 2013 11:06 |
boundary conditions problem with mesh created in Icem | darazsbence | CFX | 3 | February 24, 2013 05:02 |
[ICEM] Mesh Extrusion problem in ICEM | James Hetfield | ANSYS Meshing & Geometry | 0 | July 8, 2012 16:42 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 07:28 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
