The Mechanical Input File in workbench CFX-Pre
Old   June 25, 2014, 06:00
Default The Mechanical Input File in workbench CFX-Pre
Yangmeng
a_boy_a_girl is on a distinguished road
I have studied workbench for only several weeks,so I have lots problems.Now the most serious problem is Mechanical Input File.After I set other parts well and have an update,a book I learn says that the structural file will import automaticly,which is ds.dat.But there is a problem as follows:
In Analysis 'Flow Analysis 1' - Analysis Type - External Solver Coupling: The specified Mechanical Input File could not be opened. Please check that the file path is correct and the file exists.
In Analysis 'Flow Analysis 1' - Analysis Type: The specified Mechanical Input File 'E:\ANSYS Leraning\blood_6_20\bleed-6.20_files\dp0\SYS\MECH\data_transfer_only_ds.dat' can not be found or does not contain any valid interfaces. Specify an input file with valid interfaces, update the file location if it has moved or set the External Solver Coupling option to 'ANSYS MultiField via Prep7'.
Please help me!
a_boy_a_girl is offline   Reply With Quote
Old   July 3, 2014, 14:26
stumpy is on a distinguished road
Delete the Mechanical to CFX-Pre link on the project schematic, refresh CFX-Pre, then create the link again.
stumpy is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 11:45
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
