May 14, 2014, 08:06 |
geometry,cfturbo
tmeysam92
Rep Power: 15 |
hi guys,
i have a question when i import the geometry of a impeller and volute of a centrifugal pump to ansys geometry, it just contains surfaces. but i want to use the geomtery for fluid simulation, and it needs to be in solid form. how can i convert the surface model to solid in ansys design modeller. thanks in advance. Meysam. |
May 15, 2014, 09:55 |
Rep Power: 15 |
I would try Sew method. In the DesignModeler it is under menu Create -> Body Operation -> Sew. Cheers |
June 30, 2014, 04:31 |
mostafa faraji
hi dear Meysam,
i am student in iran and my course projet has been defined as optimization of centrifugal pump's volute casing... i need volute and impeller geometry for doing my project, i really appreciate you if you help me by sending your data (volute and impeller model and mesh data). best regards email: Mostafa.faraji91@gmail.com |
