parametric study with design modeler and icepak
Old   April 22, 2014, 04:29
Default parametric study with design modeler and icepak
amine
aminem is on a distinguished road
I have a question on parametric study on Icepak.
I can do a parametric study when I use the internal geometry of heatsink on Icepak, but when i want to use a Design Modeler to design heatsink i can't do a parametric study on icepak. I had try three strategy:
1- Define a geometrical parametre on design modeler.
2- Define a geometrical parametre on Icepak.
3- Define a geometrical parametre on both.
These strategy does not work.
Can anyone tell me if it's possible to do a parametric study with Design Modeler and icepak, and how we can do it?
Thanks
aminem is offline   Reply With Quote
Old   May 20, 2014, 08:36
Pramodh.J
Jupudi.pramodh is on a distinguished road
Send a message via Skype™ to Jupudi.pramodh
If i understand your concern properly, you were looking for a solution to perform parametric study using workbench and icepak. I don't think it might be possible. But you can perform parametric study of heatsink directly using Icepak: Optimization module.
If the geometry is some what complex that it can not be modeled in Icepak, You can use design modeler and fluent interface to perform the parametric study.
please let me know if my information is helpful
thanks
Pramodh
Jupudi.pramodh is offline   Reply With Quote
Old   May 21, 2014, 06:05
amine
Thank you for your response
Yes I have a complexe geometry.
I hope that we can combine design modeler and Icepak to make parametric simulation but it's not possible.
Old   May 21, 2014, 06:11
Pramodh.J
Icepak workbench intergation is to perform geometry cleanup / geometry creation in workbench and import the same to icepak.
This helps in importing and working with much complex geometries in Icepak. But to work with that geometry, one has to do the entire case setup in icepak.
So as far as my knowledge is concerned, we can not perform parametric study with icepak&workbench integration (when geometry changes are being defined through workbench).
Instead to handle similar situation i think you can use Workbench Fluent interface..
please do let me know your opinion
