Regarding exporting user defined range of value from CFD post to excel |
April 12, 2014, 10:56 |
ijaz fazil
Rep Power: 13 |
Hi
I have run a simulation and found velocity on the plane. Global range is very high. So I just defined the range between 0 to 8 m/s. Now I need to export these datas to excel sheet. When I export I can select only the variable, but I couldn't able to select the range. What Shall I do to select the range.(Global range is between -20 m/s to 30 m/s). But I need only 0 to 8 m/s. |
cfd post, excel, fluent 14.5 |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 10:26 |
Parallel process & CFD POST | jypark | FLUENT | 2 | August 15, 2013 00:49 |
CFD Post: Difference between calculated surface values using different methods | Shawn_A | CFX | 11 | July 30, 2013 14:07 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 05:06 |
User defined remeshing vs ICEM CFD replay remeshing | vmlxb6 | CFX | 0 | October 18, 2010 02:58 |
