Coupling Error Between ANSYS Transient Structural and Fluent |
March 12, 2014, 04:18 |
Ayuba Jonathan
Hello all,
I hope you are all doing good and I wonder if any of would be kind enough to help me with this problem: 'the current flow time obtained from the fluent input file did not match the initial time obtained from the system coupling service' I have coupled a transient structural system with CFD fluent and get the error above. I have also attached a clip of the problem. Thanks in advance for the much anticipated help. Cheers A.J |
March 18, 2014, 09:30 |
Alex
Rep Power: 12 |
Have you tried to change the timestep settings in fluent to fixed and put in the value of timestep you choose for system coupling? I have always done it like that and never had that kind of problem. Also, did you make sure that your data transfer from fluent to structural is data transfer 2? I experieced problems when the number of data transfer from structural to fluent was not 1.
fluent 14.0, system coupling error, transient structural |
1 way and 2 way FSI in ANSYS Workbench with Fluent and ANSYS Structural | jwillie2000 | FLUENT | 6 | November 26, 2017 23:21 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 09:43 |
1-way time step problem in doing FSI between Fluent and Transient Structural | sihaqqi | ANSYS | 0 | November 21, 2013 02:45 |
FLUENT - transient mechanical coupling | bogart | FLUENT | 0 | November 12, 2012 10:00 |
From Fluent 6.23 to ansys 12 structural | Rich1979 | FLUENT | 0 | April 18, 2011 09:40 |
