[Workbench / Fluent] 2D Parametric Study
Old   March 7, 2014, 04:25
Default [Workbench / Fluent] 2D Parametric Study
Ben Engel
be205 is on a distinguished road
Morning CFDers,
I've been running into a frustrating issue whilst using DesignModeler and Fluent in the workbench. Rather than continue hitting my head against a wall, I'd love to be saved the pain and get some help here!
Case Setup (extremely simple):
  • Shrouded hydrokinetic turbine (ie river current turbine)
  • 2D Shroud (ie confusor+diffusor) in a large rectangular domain, rotor is left out in this current case. I have it modeled as an actuator disc in CFX, will presumably make use of the fan model to represent it here in 2D for fluent.
  • Parametrised optimsation, making use of DoE approach to modify various aspects of geometry.
Problem:
  • I need some form of surface monitors to monitor pressure across shroud inlet and shroud outlet, as well as in the plane of the rotor. I have tried 2 approaches:
    • Attempting to insert internal lines during geometry creation in DesignModeler via create lines from sketch + project line to surface results in invalid 2d geometry errors when attempting to mesh.
    • Inserting surface monitors in Fluent itself - works fine for an individual case, however I am doing a parametrised optimsation and these surface monitors don't change with the geometry (to my knowledge)
My Questions:
  • What can I do to ensure correct 2D geometry with the first approach?
  • Can I parametrise surface monitors in such a way that they stay in the correct location after a geometry change?
Any help would be immensely appreciated. If diagrams etc. are required, say the word!
Best regards,
Ben
be205 is offline   Reply With Quote
actuator disc, designmodeler, fluent, turbine
Parametric study by Ansys Workbench Sahar FaPerhu ANSYS 17 August 23, 2017 04:29
Parametric Study - Multiple Configurations in ANSYS CFX kskong CFX 1 June 7, 2016 09:22
Parametric study and time dependent parameter monitoring Crustulu FLUENT 1 April 12, 2013 06:54
Parametric Study victoryv FLUENT 3 January 31, 2013 21:29
Parametric Study Murat FloEFD, FloWorks & FloTHERM 1 October 13, 2008 04:20
