temperature increases to unreasonable value
Old   February 24, 2014, 05:48
Default temperature increases to unreasonable value
Han Zhou
quinette is on a distinguished road
Hello
I am relatively new to ANSYS Fluent
I was trying to model a system consist of battery pack and cooling plate, the only fluid is the cooling water, while the other parts are solid with defined physical properties.
After I start the calculation, the temperature in some zones went up to several thousand degree, the error looks like this:
"temperature limited to 5.000000e+03 in 78 cells on zone 14 "
But the peculiar thing is, I didn't even define a heat source inside the system. (the initial temperature is 300K and cooling water is even lower-290K)
Could anyone give a clue why the energy increases ?
Thank you very much.
quinette is offline   Reply With Quote
energy increase, fluent error, temperature over limit
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Static Temperature / Opening Temperature JulianP CFX 12 April 10, 2019 19:00
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Closed Volume: Mass increases, pressure and temperature decrease... vainilreb OpenFOAM Running, Solving & CFD 1 December 4, 2012 08:57
