how can we get flutter speed from 2way fsi??
Old   December 30, 2013, 00:36
Default how can we get flutter speed from 2way fsi??
siddu
siddu.pk is on a distinguished road
hello
i m doin transonic aeroelastic analysis over an airfoil so i need to find the flutter speed, so can anyone tel me the procedure to find the flutter speed plzz,
thank u
siddu.pk is offline   Reply With Quote
Old   January 22, 2014, 06:24
levivad is on a distinguished road
In some cases you can use quasistatic aeroelastic theory to find the flutter speed. If it's good enough for you it, than you only need to calculate the lift coefficient depending on angle of attack.
If you want 2 way FSI, you can do a transient simulation. If you're above the critical velocity the flutter should develop by itself (just like a vortex street behind a cylinder). It's a very expensive calculation though.
levivad is offline   Reply With Quote
Old   January 22, 2014, 23:35
siddu
thank you levivad
2way FSI Fluent Mechanical SETUP Problems MainzerKaiser ANSYS 7 May 20, 2016 12:22
2way FSI with Ansys workbench lingdeer ANSYS 3 May 9, 2013 04:48
Does Fluid Structure Coupling between CFD-FEM solves can predict Flutter Speed? Engr.RZA Main CFD Forum 1 December 10, 2012 19:45
FSI and flutter pop CFX 11 July 26, 2011 12:48
Two way FSI and flutter of fan blade Nevel CFX 1 October 6, 2009 18:43
