November 25, 2013, 04:22 |
Export data on line
Tamara Annabelle
Rep Power: 13 |
Hello everybody!
I am simulating the flow and heat transfer in a channel. I want to export data in CFD-Post on a line that cuts through my model orthogonally to the flow in the channel. In Inserted a line with Insert>location>line and then exported Data like Turbulence kinetic energy and velocity on that line. I already found out, that I can vary the samples exported, if I change the number of samples when creating the line. But what I am confused with is, that it exports data also some mm after my model actually ends, they are extremely small (1e-14) but it should export "null" at this points... Does it have to do with my boundary conditions (no slip wall) or is it a problem because Average values are exported? How can I get around this problem? I already tried augmenting the number of samples. Maybe the option "cut" when creating the line helps? But I didn't find anything in the guide about what this option does... velocity profiles.JPG I would be grateful for some ideas or tips where I can find how CFD-Post exactly exports the data. Thanks, Mara |
November 25, 2013, 04:31 |
Tamara Annabelle
Rep Power: 13 |
ok, I tried out the cut option, seems like it works, but hte problem now is, that I have different nummer of samples on each line and for evaluating my data I already have written a makro where it needs the same number of samples on each line... Any ideas how I can to solve the problem?velocity profiles1_cut.JPG
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
OpenFOAM15 installables are incomplete problem with paraFoam | tryingof | OpenFOAM Bugs | 17 | December 7, 2008 05:41 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 22:45 |
