simple open ended pipe flow with moving piston
Old   November 21, 2013, 10:55
Default simple open ended pipe flow with moving piston
Lisa Marfell
lmarf88 is on a distinguished road
I am very new to CFD and have only had one tutorial on the software ANSYS FLUENT 14.5 and workbench 14.5.
I am trying to create a simple 2D model representing a moving piston in an open ended pipe. The pipe has a constant diameter of 50mm. Eventually I want to model a moving piston in a rapid compression machine, but to get to grips with the software and modelling, I have decided to start with a simple open ended cylinder.
I have seen some video examples of this using dynamic meshing to represent a moving piston
http://www.youtube.com/watch?v=KadTHtkCxKA, I want to simulate a model similar to this, but the end of the cylinder to be open-ended.
I cannot find any tutorials for how to simulate this model, only tutorials of dynamic meshing with a valve rather than piston, and these tutorials are from a much older version of the program.
If anybody could help me or point me to a more relevant, updated tutorial that would be very helpful.
Thanks,
Lisa
lmarf88 is offline   Reply With Quote
Old   November 22, 2013, 22:12
aditya singh
Adi singh is on a distinguished road
You Should Define moving mesh . and similar example is in Fluent tutorials. That would help you.
Adi singh is offline   Reply With Quote
ansys, moving piston, open flow
simple open channel flow, the inlet and outlet are periodic Sniper OpenFOAM Pre-Processing 31 December 28, 2023 03:12
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
Cannot validate simple pipe flow using simpleFoam inf.vish OpenFOAM Running, Solving & CFD 4 August 6, 2013 08:32
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? karkar OpenFOAM Meshing & Mesh Conversion 0 July 4, 2012 07:54
SIMPLE Scheme for open channel flow ao Main CFD Forum 0 April 6, 2004 17:21
