Give Variable from Workbench Scripting to CCL
Old   November 19, 2013, 08:29
Default Give Variable from Workbench Scripting to CCL
Robert
Axlex is on a distinguished road
i want to run some CFX-Simulations with different parameters. Therefor i want to use Workbench Scripting. A short example:
SetScriptVersion(Version="14.5")
system1 = GetSystem(Name="CFX")
setup1 = system1.GetContainer(ComponentName="Setup")
TurbulenceModel = "SST", "BSL Reynolds Stress"      #Array of Strings
for i in TurbulenceModel
     setup1.SendCommand(Command="""
          TURBULENCE MODEL:
		Option = Turb[i]                   #Insert Current Array String
	  END # TURBULENCE MODEL:
What i want to achieve, is to give the values of the array to the system components of CFX. The problem is, that they use different programming languages, workbench-python and CFX-perl.
Does anyone know how to do this? I did not find any information about this in the help or the internet.
Regards
Robert
Axlex is offline   Reply With Quote
Old   November 25, 2013, 04:47
Robert
Ok,
I thought so, that there isn't a solution. My Workaround is to use a Text file, where i store the necessary values.
Regards
Robert
ccl, perl, python, workbench scripting
How to give enough info to get help linnemann OpenFOAM 8 September 20, 2017 10:19
Embed explicitSetValue in chtMultiRegionFoam samiam1000 OpenFOAM 2 April 18, 2012 06:14
In CFX workbench, which surface, i have to select senCFX CFX 19 December 19, 2011 02:31
How to use / How to find IPMT? camoesas CFX 2 November 23, 2010 07:36
How to limit a variable ash OpenFOAM Running, Solving & CFD 1 June 26, 2008 21:32
