Excel in Ansys WB
Old   May 22, 2013, 09:49
Default Excel in Ansys WB
Ano Nymous
Halle is on a distinguished road
Hi there!
I'm trying to run an optimization on Ansys Workbench. The geometry is created from parameters in an Excel-file and exported by a macro. The macro creates .txt-files which are supposed to be used by ICEM as formatted point data.
The whole setup works fine with the exception that the geometry and mesh in ICEM are not updated. Because of this the same mesh is transferred to CFX, leading to the same solution for every design point.
Does anyone have an idea what the problem might be? Or even know how to solve it?
Halle is offline   Reply With Quote
Old   May 28, 2013, 03:05
Ano Nymous
I have made some progress so far. I used a dummy parameter to force ICEM to uptdate. Unfortunately this only works whenever this parameter changes - otherwise the optimization routine will use the old mesh and geometry.
Is there a possibility to force a parameter to change every single step in WB? Something like an upcount or CPU clock?
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
Running Ansys in BAtch Mode kuleuvenstudent ANSYS 1 October 18, 2017 13:11
Fluid structure interaction jnattia Main CFD Forum 25 May 21, 2015 10:16
ansys workbench interface with excel shree272 ANSYS 0 April 6, 2013 04:48
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
