Ansys 14 system coupling restart
Old   May 12, 2013, 15:39
Default Ansys 14 system coupling restart
levivad is on a distinguished road
I'm simulating a transient coupled analysis of a fluid structure interaction using Ansys 14 with system coupling ( transient structural and fluent).
my analysis requires very long runs, so I've written a script to stop the analysis, save and resume.
This worked fine for the uncoupled analysis (it was performed earlier as a basis for comparison).
I've set up the coupled analysis, and made sure it runs properly.
But when the analysis is stopped and i try restarting it, an error occurs saying no *.ldhi file is found, and the restart is aborted.
I've checked that my restart settings in the structural analysis are OK, and when running just the structural system the *.ldhi is there, and restarts are OK.
can anyone help with this?
levivad is offline   Reply With Quote
Old   May 18, 2013, 07:03
Nobody has any insight?
Thanks,
Levivad
Old   September 5, 2013, 07:48
Ali.E
behest is on a distinguished road
Hello my friend,
I am trying to simulate fluid structure intraction like you (transient structure and fluent, using system coupling in workbench 14). actually, I generated msh file in gambit and then calculated fluid flow in the fluent seperately. subsequently, I drew the FSI in workbench and read mesh file for geometry, case/dat file for fluent. I actived dynamic mesh and select coupling system for walls, too. In transient structure, I read geometry and fluid-structure interaction is selected.
As a result, can you introduce a toturial or explain the way that I should perform it? As you simulated FSI, you may have some toturials or files that be usefull for me. I do not have any idea for it
behest is offline   Reply With Quote
ansys 14.0, system coupling error
Problem in coupling CFX and Ansys for fluid-thermal sim. Jordi CFX 21 March 1, 2017 06:03
Remeshing_ ANSYS 14.0_ System Coupling acdesa ANSYS 4 November 2, 2016 10:12
system coupling ansys 14 - error karupps8 Main CFD Forum 1 May 20, 2014 22:36
FSI, Fluent Ansys coupling Greg Carnie FLUENT 5 January 7, 2010 20:15
Need ideas-fuel discharge system Jan FLUENT 1 October 11, 2006 00:05
