Adjoint - topology optimization - custom control volume
Old   May 3, 2013, 07:03
Default Adjoint - topology optimization - custom control volume
TonyD
bramv101 is on a distinguished road
All,
I would like to optimize the pressure loss of a duct through morphing its topology.
Is there a way i can use the adjoint solver in combination with a custom control volume?
Or is adjoint not even the way to go?
bramv101 is offline   Reply With Quote
Old   May 16, 2013, 08:25
TonyD
Nobody an answer on this one?
Old   May 17, 2013, 02:55
revilo82 is on a distinguished road
Hi bramv101,
you can do topo optimization with Fluent Adjoint Solver:
1. CFD & AS run
2. Find relevant min/max values for the 'Adjoint Flow Blockage' by Contour Plot and mouse probe
3. Mark the cells with ADAPT/ISO VALUE by using 'Adjoint Flow Blockage' variable
4. If you cannot mark the cells (zero cells marked) use the following Scheme command: (%free-parents)
5. Visualize the marked cells (Adapt Manager)
6. Separate marked cells by MESH/SEPARATE/CELLS
7. Delete the new cell zone(s) by MESH/ZONE/DELETE
You can only create the parallelepiped control volume. For topo optimization you don't need this feature.
revilo82 is offline   Reply With Quote
Old   May 27, 2013, 07:07
TonyD
Revilo,
correct me if i understood wrong:
1. import my dimension envelope
2. run cfd+as
3. find my min-max values (is this determined on gut feeling?)
4. select all cells that i want to see removed (based on min/max values)
5. remove cells and rerun on newly formed domain
6. optional: export this new domain as guideline for the CAD designers
honestly I have no clue on how to actually do step 3+4+5?
Would you see it possible to get me some screenshots?
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Help for learning about Adjoint Method in optimization EmadTandis Main CFD Forum 0 March 15, 2013 05:55
Discrete Adjoint Optimization ? Tommy Chen SU2 Shape Design 1 March 5, 2013 15:08
Structural Topology Optimization sailor79 OpenFOAM Running, Solving & CFD 3 August 23, 2012 04:21
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 16:34
