Multiple Thermal Conductivity for a Material at different temperature
Old   April 17, 2013, 21:24
Default Multiple Thermal Conductivity for a Material at different temperature
AJ Hunter
ajhunte is on a distinguished road
I am trying to create a material in ANSYS that has a different thermal conductivity at different temperatures. I tried the following:
Creating a function "Function 1" with my data:
-Argument Units: K
-Output Units : W m^-1 K^-1
Creating an expression "Expression 1" linked to the function:
-Expression 1= Function 1(K)
This gives me the following error:
Bad expression value 'Expression 1' detected in parameter 'Thermal Conductivity' in object '/LIBRARY/MATERIAL:Zirconium/PROPERTIES/THERMAL CONDUCTIVITY'.
CEL error:
The following unrecognised name was referenced: K.
Which basically says that I can't use K as the input to my function?
ajhunte is offline   Reply With Quote
Old   April 18, 2013, 03:59
vagantes is on a distinguished road
-Argument Units: K
CEL error:
Hi ajhunte !
from the info you have given, it seems that you have tried to modify an element's properties from the MATERIALs library. Something is wrong with you re-definition. Could you provide additional info - what module of ANSYS do you use?
Possible solutions for the definition of temperature dependence of thermal conductivity:
1. if you use Transient module, you can specify temperature dependence of thermal conductivity in a Table form in the section 'Engineering Data'.
2. if you use FLUENT module, you can define a User-Defined Function (code it in C) and either compile or interpret it, and then use this function in material's properties specification. (There is a reference guide on how to make the User-Defined Functions in FLUENT).
regards,
vagantes is offline   Reply With Quote
Old   April 20, 2013, 11:15
dklastiwka's Avatar
Derek Lastiwka
dklastiwka is on a distinguished road
This looks like it is in CFX. Try putting square brackets around K. Like this:
[K]
Derek Lastiwka
Mechanical & Fluids Engineer
dlastiwka@graymattereng.com
Gray Matter Engineering Inc.
dklastiwka is offline   Reply With Quote
interpolation data, thermal conductivity, user material
Problems with CEL (guess it's simple to solve) Felggv CFX 22 March 26, 2019 17:42
Thermal conductivity UDF jack.s Fluent UDF and Scheme Programming 4 February 29, 2012 12:57
Multiple domain/Multiple material problems... possible or not? Amiga500 OpenFOAM 1 April 14, 2010 16:32
Inteface thermal conductivity ado Main CFD Forum 4 March 11, 2002 20:46
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
