April 9, 2013, 04:16 |
Heat transfer between solid and fluid
Suyash Patkar
Rep Power: 13 |
hi,
I am modeling the flow in pipe which is surrounded by soil. I am interested in finding the heat transfer between the fluid to soil. But I am not able to see any heat transfer between two medium. I have created the conformal mesh.I have found out the 'wall-shadow' is formed at the interface boundary for heat transfer. I am not sure where I went wrong as there is no heat transfer occurring from solid to fluid medium? |
April 12, 2013, 09:38 |
Ice Lee
Rep Power: 15 |
I think you didn't model it well.
For a good mesh that solid and fluid coupled, there should be a wall and a wall.shadow. If there is no wall.shadow that means fluid zone and solid zone are isolated. No heat will be able to to through the wall. ---------------------------manual signature----------------------------- HangZhou Deep Ice tech, expert in CFD, thermal design http://www.hzice.com/Hzice_eng/index.html |
April 12, 2013, 09:55 |
Suyash Patkar
Rep Power: 13 |
Thanks for your reply.
I got the wall and wall.shadow in boundary condition. Still I am unable to find any heat transfer from solid to liquid region. |
April 13, 2013, 10:59 |
upload your case
Ice Lee
Rep Power: 15 |
Upload your case and I will help to check it.
April 22, 2013, 15:59 |
heat transfer between fluid and solid fluent
#5 | |
samt
Rep Power: 16 |
I have same problem Can you help me thanks a lot Best Regards... |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Solid / Fluid Heat Transfer | Koranten | FLUENT | 3 | March 19, 2011 07:21 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
