Spring Modelling and loading
View Poll Results: which is the best method for loading a spring in ANSYS13
nodal application 0 0%
using key points 0 0%
Voters: 0. You may not vote on this poll
Old   March 23, 2013, 12:59
Default Spring Modelling and loading
Tona Sam Thomas
hotshotracer is on a distinguished road
we are doing a project in ANSYS 13.0. Topic is '" ANALYSIS OF SHAPE MEMORY ALLOY" .We have done the simulation on a beam and an aerofoil.For the validation we need to do the same with a spring.
We modeled the spring,but we need to compress the spring.But it is difficult by fixing the end nodes and applying the load in nodes because the nodes are in different plane.So we need an alternate method for the compression loading........Kindly suggest a method
hotshotracer is offline   Reply With Quote
compression, spring method
Problems with es-ice in linux and modelling of the valve profile MRI STAR-CD 6 October 24, 2013 03:54
Gasification modelling using non-premixed combustion nurul efha FLUENT 0 November 12, 2012 04:57
Gasification modelling using non-premixed combustion nurul efha Main CFD Forum 0 November 8, 2012 05:08
Modelling the heat transfer during compression and cooling of natural gas pano Main CFD Forum 0 December 10, 2010 16:53
