Airflow over Vertical Axis Wind TUrbine
Old   March 1, 2013, 10:03
Default Airflow over Vertical Axis Wind TUrbine
sthoms78 is on a distinguished road
I'm trying to perform analysis on a vertical axis wind turbine using ansys workbench. I need to calculate the airflow through my designs. I don't have any experience using workbench and i was hoping some people have guides/tutorials that are easier to follow than those available on the ansys portal.
Thanks!
sthoms78 is offline   Reply With Quote
Old   March 2, 2013, 11:12
b
Drgo is on a distinguished road
This is just the basics scott.
Drgo is offline   Reply With Quote
Old   April 2, 2013, 09:27
I'm mostly having issues with the initial setup of the meshing. I'm porting my model from pro engineer and creating an enclosure round it then meshing both enclosure/model. However in the setup phase of the cfx solver i can only see my enclosure and not my turbine. Does anyone know where I'm going wrong?
Old   April 3, 2013, 05:09
Bahar
bahar is on a distinguished road
You need to create some zones to mesh. Which method do you use as the technique of modeling for rotation of turbine? Which package are you using to create mesh?
Could you post a picture of your turbine?
Regards,
Bahar
bahar is offline   Reply With Quote
Old   April 3, 2013, 13:39
Sorry, I don't have a clue which technique I'm using. It's not going to contra-rotating of anything like that. I'm meshing using the meshing tool available in ansys, that's probably not very helpful but i don't really know what I'm doing
Here's a link to my initial design
http://tinypic.com/r/2m2vwo8/6
Old   April 3, 2013, 20:02
Default Turbomachinery
Ricardo
ricardo.costa is on a distinguished road
Maybe you can try starting studying the documentation about turbomachinery. There is a special course developed by Ansys about this. Try to download it.
In your model, for example, you can an axisymmetric study with Rotational symmetry. In this way, you can make a most fine mesh increasing the quality of your results.
Regards,
Ricardo
ricardo.costa is offline   Reply With Quote
Old   April 4, 2013, 03:08
Bahar
You have two rotating zone and one stationary(Domain). In order to create mesh around such a geometry you should divide domain to 3 parts and mesh each separately.
Which software are you using to mesh?
Regards,
Bahar
Old   April 4, 2013, 07:25
I am using ANSYS Workbench (with DM, Meshing and CFX), i don't have access to any external meshing software as I'm using my universities software.
For creating the 3 parts I'm guessing that one is the central shaft and the two rotating sections will be meshed separately too?
Thanks
Old   April 10, 2013, 03:31
Bahar
I didn't worked that mesh tools, so I cannot help you in this way. But I have modeled a VAWT and I could help you by Defining Domain and Boundary Conditions.
You need two rotating zones related to each turbine and a stationary zone out of them as Domain. It dose not need to define a separate zone for central shaft.
How did you create your domain?
Vertical Axis Wind Turbine atorninc Main CFD Forum 3 March 6, 2013 05:38
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
Reversed flow in Vertical axis wind turbine Anonymized_JL1 FLUENT 2 April 11, 2012 04:13
Vertical axis wind turbine in NUMECA ArslanOZCAN Fidelity CFD 2 July 21, 2011 06:04
3 bladed Vertical Axis Wind Turbine transient CFD ArslanOZCAN FLUENT 1 February 5, 2011 09:34
