February 4, 2013, 10:52 |
Ansys Workbench - setting up batch processes
Rep Power: 16 |
Hello everyone,
I'm having an issue with ANSYS Workbench right now. I haven't been working with the WB so far, I've been doing the simulations seperately - pre, solver, post. To speed up the process, I want to use the WB to set up some processes, that run one after the other. I'm doing the mesh and the pre outside of the WB, load them to the WB and want the solver run over night. After finishing the 1st, the 2nd starts and so on - one simulation after the other. I suppose that should be pretty easy to set up, but as I'm totally new to the Workbench, I don't know where to start. Could you please give me some hints how to deal with this issue. Thanks a lot, Erik Last edited by sErik; February 7, 2013 at 03:59. |
February 6, 2013, 09:10 |
Rep Power: 16 |
Hi guys,
even some hints on tutorials are appreciated. I've checked them on the Ansys HP but couldn't find anything helpful. |
February 7, 2013, 01:26 |
Martin Larsen
Rep Power: 13 |
You could try to look into the parameter capabilities workbench have.
Try the links: http://ebookbrowse.com/cfx-overview-...pdf-d336087644 http://ebookbrowse.com/fluent-overvi...pdf-d114598367 As far as I know, the process is the same for other simulation tools run from Workbench |
[ANSYS Meshing] trying to mesh a saloon car in wind-tunnel with Ansys 13.0 Workbench mesher | IvanCFD | ANSYS Meshing & Geometry | 10 | July 8, 2014 15:55 |
2way FSI with Ansys workbench | lingdeer | ANSYS | 3 | May 9, 2013 03:48 |
airfoil drawing in ansys workbench | Hammam | ANSYS Meshing & Geometry | 2 | June 18, 2011 19:34 |
How to mold liquid metal using ANSYS WORKBENCH | nick0100 | ANSYS | 0 | January 5, 2010 03:33 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 14:26 |
