ANSYS AUTODYN 3D simulation
Old   December 13, 2012, 04:25
Default ANSYS AUTODYN 3D simulation
ATD
Aleksander
ATD is on a distinguished road
I am a new user of ANSYS AUTODYN, and I met obstacles during my modeling very quickly. I am modeling a pressure waves inside of a pyrotechnic actuator. At the beginning everything was pretty straightforward. I designed a 3D model in Explicit Dynamics module, then set up the AUTODYN model. However every simulation ended up with this same result. Namely the piston moved for some distance then stopped and went beck. After a while moved forward again. I have applied different meshes, different connections between material, etc. but no matter what I have done with the model there was this same result over and over again. I have no idea even when to look a problem. I will be very grateful for any hint. I set EOS of every part to „rigid”. Can it be the source of the problem?
Thank you
ATD is offline   Reply With Quote
ANSYS CFX volume fraction definition for multiphase simulation juliom CFX 11 January 24, 2018 06:32
simulation of a radial hydrodynamic bearing in ANSYS CFX Jalen ANSYS 1 October 4, 2013 11:40
ANSYS AUTODYN parts with "Rigid EOS" ATD ANSYS 0 December 12, 2012 08:06
laser moving heat source simulation in ansys rajat27feb ANSYS 0 September 6, 2012 07:41
valve simulation in ansys cfx Franco CFX 0 July 3, 2008 06:33
