September 16, 2012, 11:46 |
Ansys 14 on Ubuntu 12.04
Mariano
Rep Power: 14 |
Hy all,
i have installed Ansys 14 on Ubuntu 12.04 precise 64 bit. I had no problem with installation, but i can not complete the procedure for the correct specification of the license file. In few words, when i indicate the license file, the license manager returns the message that the FLEXID in the license file does not correspond to the one of the system. Indeed, when i visualize the FLEXID by means of the license manager utility i find a series of zeros. According to my experience, this is might be caused by the LSM package, but i have it installed on my machine. May be the cause of this problem the installastion directory? I installed Ansys into my home directory, not into the default directory /usr. Morevover, may be the cause the libXm.so library? I do not have it: how can i install it? Many many questions....I hope in your support! |
September 17, 2012, 04:05 |
Mariano
Rep Power: 14 |
Anyone can help me?
October 2, 2012, 12:41 |
Dogan
Rep Power: 16 |
did you use -no root commant on starting of the ANSYS.
As I know ANSYS require to setup in /usr |
October 2, 2012, 13:09 |
Mariano
Rep Power: 14 |
I try to open the license manager both as root and stardard user: in any case, i always get a serie of zero when i visualize the machine hostid of my pc, via the license manager.
This is a critical issue because the licecense manager does not recognize the host id in the license file: so can not open any program of Ansys Workbench. Anyway, thanks for answering! |
October 2, 2012, 20:11 |
Dogan
Rep Power: 16 |
you have to use
sudo ./INSTALL -noroot command to install the ANSYS. After you will use LM. |
October 6, 2012, 13:58 |
#6 | |
Mariano
Rep Power: 14 |
Which commands i have to use ? I know i must be root during installation of Ansys and License Manager; the i change the ownership of the various ansys folders. My problem is: FLELXlm does non start..... Anyway, thaks for your previous answers! |
October 6, 2012, 13:59 |
Mariano
Rep Power: 14 |
...sorry for my english! i wrote too fast!!
October 19, 2012, 10:31 |
Rep Power: 14 |
Hola Mariano,
I think you should repeat the whole intallation process like somebody said: sudo ./INSTALL -noroot You can't start FLELXlm because it wasn't probably properly installed. Try it again and let us know what happens. Ansys is only tested to work in Suse and Red Hat teorically, but I am planning to install it in Ubuntu too. |
October 19, 2012, 10:34 |
#9 |
Rep Power: 14 |
By the way Ubuntu 12.10 came out yesterday. I am planning to install it in some days, and ansys on it.
October 28, 2012, 08:04 |
#10 | |
Mariano
Rep Power: 14 |
Meanwhile i found a problem with flexlm: probably the flexid of my pc is not recognized because the installation of flexlm, during ansys installation, has not been completed properly....I don't know how to solve the problem!! |
March 2, 2013, 01:29 |
#11 |
Dmitry
Rep Power: 15 |
u will need to install Linux Standard Base (lsb)
Errors while installing openfoam on ubuntu 12.04 AND 11.10 | fshak92 | OpenFOAM Installation | 27 | May 1, 2021 13:10 |
Installation on Ubuntu 12.04 LTS | samiam1000 | OpenFOAM Installation | 11 | May 26, 2012 06:54 |
Openfoam 2.1 installation in ubuntu 12.04 | jsm | OpenFOAM Installation | 11 | May 7, 2012 05:56 |
Ansys 13 - License problem on Ubuntu | MarTar | ANSYS | 4 | February 3, 2012 03:13 |
Ansys 13 64 bit Linux (ubuntu) licencing | epilson | ANSYS | 4 | December 16, 2011 04:15 |
