July 24, 2012, 10:25 |
Ansys Workbench - Structural
Jean-Philippe Guérin
I would like to know how to insert a pressure on a certain diameter. In my problem, I have a circular disc of 200mm diameter. I need to insert a pressure of 2 MPa in the center of my disc, and on a diameter of 30mm. I can't find a way to add a pressure not on all the surface of the top of my disc. Thanks for your help, JP |
July 24, 2012, 23:19 |
Gwenael H.
Rep Power: 20 |
Hi Jean-Philippe,
Well one easy way is to slice your geometry in DesignModeler, then form a new part with all the sub-parts (to have a single mesh), then in Mechanical you can easily select your sub-surface to apply your pressure load. This is not an elegant way to do it but I think it's the quickest and easiest way (I'm not aware of another way) . Bon courage |
ANSYS Workbench on "Uncertified" Linux Distros | hsr | CFX | 289 | April 20, 2023 10:23 |
[ICEM] what does the different ANSYS ICEM and ANSYS Workbench? | agungwp | ANSYS Meshing & Geometry | 8 | April 12, 2016 05:51 |
Macro command combatibility ANSYS workbench | Tassos | CFX | 6 | January 13, 2014 05:19 |
Ansys workbench problem | Jonny6001 | ANSYS | 2 | September 30, 2010 13:59 |
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! | Cirion0000 | CFX | 0 | July 6, 2009 15:26 |
