July 6, 2012, 10:18 |
fsi question
tmeysam92
Rep Power: 15 |
Hi all,
my question is about FSI(fluid structure interaction). i want to couple fluent with transient structural. my case in fluent is unsteady, and the deformation is important. now i want to know my case is one way or two way coupling??? if the deformation is not very important, how would be the system coupling??? thanks in advance. meysam |
July 8, 2012, 21:05 |
Gwenael H.
Rep Power: 20 |
Have a look at the CFD Wiki on FSI
Here is a figure extracted from a research article of applied mathematics, "A Comparison of One-Way and Two-Way Coupling Methods for Numerical Analysis of Fluid-Structure Interactions". FSIcoupling.jpg If your setup implies large deformation then you need mesh morphing so you should realize 2 way FSI, otherwise for small deformation you can use 1 way. |
July 9, 2012, 12:51 |
tmeysam92
Rep Power: 15 |
thank you very much for your reply.
July 9, 2012, 14:43 |
reply
#4 | |
tmeysam92
Rep Power: 15 |
is there possible to have a transient solution and using one-way fsi? if yes how? is there any tutorial about this kind of problem? |
User-defined force transfer across FSI interface | vivekcfd | CFX | 7 | March 10, 2010 21:43 |
BCs in an FSI simulation of a flexble pipe | vivekcfd | OpenFOAM | 10 | January 8, 2010 05:14 |
initial file for fsi modeling? | mortazavi | CFX | 0 | July 21, 2009 03:06 |
1-way FSI Vs. 2-way FSI | k_buz | Main CFD Forum | 0 | May 12, 2009 05:10 |
fsi | sun | Siemens | 8 | January 20, 2009 00:17 |
