Problem with GAMBIT
Old   June 20, 2012, 08:42
Default Problem with GAMBIT
Francesco
Bombolati is on a distinguished road
Hi, I'm trying to convert a mesh in GAMBIT v2.2.30. The extension of my starting file is .cas and I want a .msh. To do this, first I've to open my .cas file. If I click <<file>>, <<import>>, <<mesh>>, under the <<type>> menu I select Fluent 5/6, dimension is 2D, then I select my file but GAMBIT give me this error:
ERROR: Error encountered while reading the header information.
GAMBIT is unable to import |utility fe2ram -m1e-006 -d2 -tRAMPANT -oFIDAP7 C:\Documents and Settings\Utente\GAMBIT.568\caso1.cas
further information may be available in the Gambit start
window/terminal
What about the error? What I have to do? Please help me!
Thanks a lot
Bombolati is offline   Reply With Quote
[GAMBIT] problem with importing geometry in Gambit bahar ANSYS Meshing & Geometry 27 December 12, 2014 01:57
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 03:33
Gambit starting problem Kwiaci ANSYS 0 December 4, 2011 06:43
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Meshing & Mesh Conversion 25 September 11, 2011 08:58
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 12:09
