o-grid problem in ICEMCFD
Old   May 31, 2012, 23:33
Default o-grid problem in ICEMCFD
Streamlet
Streamlet is on a distinguished road
Hello everyone
I splitted a block to o-type ,but the internal block deforms to a total circle after projecting to mesh shape, would anyone help me?
Thank you very much!
Streamlet is offline   Reply With Quote
Old   May 31, 2012, 23:39
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
can you explain your question bit more and also please attached the files like .tin and .blk
Far is offline   Reply With Quote
Old   June 1, 2012, 00:19
Streamlet
Hi, Far
I have send the files to you by e-mail, thank you very much.
Old   June 1, 2012, 00:26
Far
Sijal
i cannot see any problem in the meshing. Every thing is fine
Old   June 1, 2012, 14:04
Far
Sijal
is there any problem with blocking? as i cannot find one!!!
Old   June 1, 2012, 23:17
Streamlet
I think I should check the blocking again carefully
Old   June 3, 2012, 10:49
Smile
shuai_manlou's Avatar
CAO Liushuai
shuai_manlou is on a distinguished road
may be you should project the outer cirlcle curve with the block's edge before you split the block with O-grid ~
shuai_manlou is offline   Reply With Quote
Old   July 3, 2012, 22:48
Haipeng Wang
toil is on a distinguished road
disassociate your inner edges may solve your problem.
PS: you can draw a few lines then associate your inner edges to force them to be straight
toil is offline   Reply With Quote
ICEM problem of orthogonality in structured layer of hybrid grid naffrancois ANSYS 2 January 18, 2012 09:14
How to setup a new problem from a grid generated in ICEM Tarak OpenFOAM Running, Solving & CFD 2 September 29, 2010 13:26
Re: Convergence problem for refined grid CFD_Novice Main CFD Forum 13 February 17, 2008 23:56
grid adaption problem justin FLUENT 3 April 8, 2006 11:45
nonstaggered grid problem Zhi-Xing Yu Main CFD Forum 7 August 26, 1998 14:22
