Meshing causing holes in ground
Old   May 29, 2012, 11:25
Default Meshing causing holes in ground
Matt
mlbbrown is on a distinguished road
Hi there,
I'm having some problems meshing a wheel as part of a car being modelled on a road.
The geometry of the vehicle is imported as a step file and then I'm creating an enclosure around it in the geometry mode before performing a cut. The enclosure settings don't permit the wheel to touch the bottom of the enclosure, so instead I have set it to a very small value such as 0.5mm.
This causes a problem when it comes to meshing as it means there is always a 'hole' in the ground where it doesn't put any elements. My next step was to reduce the minimum element size but this doesn't help the problem but instead puts a lot of very small elements in other places where the geometry is intricate (however these elements would be more than small enough to fit under the wheels).
Could any of you provide advice in this situation? Is there a way of allowing the wheels to be in contact with the ground?
(I'm using Ansys 13)
Regards,
Matthew
mlbbrown is offline   Reply With Quote
Old   May 30, 2012, 23:07
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
You need to define a thin cut at the interface of wheel and ground. Otherwise, the mesh on the wheel may penetrate into ground, and make a hole as you described.
rikio is offline   Reply With Quote
Old   March 13, 2018, 17:51
Sri Harsha Maddila
harsha2398 is on a distinguished road
How does one do this? In Designmodeler? After or before performing the Boolean subtracting the car body from the enclosure?
harsha2398 is offline   Reply With Quote
Old   March 18, 2018, 02:14
Arnie
arnie333 is on a distinguished road
Mathew,
Common practice is to model a ‘low profile’ square or rectangle patch in the contact region between the tire and the road and Boolean subtract it. It doesn’t matter that it creates a ‘hole’ on the edge of the domain boundary.
This pad will also reduce poor element Skewness and Orthogonality in that region.
arnie333 is offline   Reply With Quote
ansys 13 work bench, meshing problem
[ICEM] Annoying mesh holes on an aircraft Santos-Dumont ANSYS Meshing & Geometry 2 March 2, 2012 09:13
[GAMBIT] GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream rocketman1151 ANSYS Meshing & Geometry 7 November 30, 2011 03:39
[ICEM] Meshing a moving car on ground lihuang ANSYS Meshing & Geometry 0 March 15, 2011 11:50
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 06:01
meshing difficulties in gambit jyothish FLUENT 6 June 7, 2004 05:13
